Connect and print on the move with the ultimate portable printer. This lightweight printer can fit into a laptop bag and lets you print direct from smart devices and the cloud - with outstanding results.
Product Description | Canon PIXMA iP110 - printer - colour - ink-jet | Printer Type | Photo printer - ink-jet - colour | Weight | 2 kg | Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) | Ink Palette Supported (Colours) | 5-ink - cyan, magenta, yellow, black, pigment black | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 9 ipm - B/W , Up to 5.8 ipm - colour , Up to 0.88 min/page - photo - 100 x 150 mm | Max Resolution (Colour) | 9600 x 2400 dpi | Interface | USB 2.0, Wi-Fi(n) | AirPrint Enabled | Yes | Media Type | Envelopes, plain paper, photo stickers, glossy photo paper, matt photo paper | Total Media Capacity | 50 sheets | Networking | Print server | Printer Features | Borderless printing | System Requirements | Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Android, Apple MacOS X 10.6.8 or later, Windows 8, Apple iOS, Windows 8.1, Windows RT | Microsoft Certification | Compatible with Windows 7 | Dimensions (WxDxH) | 32.2 cm x 18.5 cm x 6.2 cm |
General | |
Printer | |
Minimum Ink Droplet Size | 1 pl |
Ink Cartridge Configuration | 1 pigment black ink tank, 1 colour ink tank (cyan, magenta, yellow, black) |
Ink Type | Canon ChromaLife100 |
Connectivity Technology | Wireless |
Direct Printing Specifications | PictBridge |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm |
Borderless Photo Sizes | ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm |
Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm) |
Media Weight | 64 g/m² - 275 g/m² |
Media Feeders | 1 x automatic - 50 sheets weight: 64 g/m² - 275 g/m² |
Networking | |
Security Protocols & Features | WEP, WPA-PSK, WPA2-PSK |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B |
Miscellaneous | |
Consumables Included | 1 x ink tank (pigmented black) , 1 x ink tank (yellow/cyan/magenta/black) |
Features | PIXMA Cloud Link |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 10 Watt |
Power Consumption Stand by | 1.8 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden |
OS Required | Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Android, Apple MacOS X 10.6.8 or later, Windows 8, Apple iOS, Windows 8.1, Windows RT |
System Requirements Details | Windows XP/Vista/7/8 - HD 3 GB , MacOS X - HD 1.5 GB |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Sound Emission (Operating) | 38.5 dBA |
Dimensions & Weight | |
Width | 32.2 cm |
Depth | 18.5 cm |
Height | 6.2 cm |
Weight | 2 kg |
