The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
Product Description | CORSAIR Value Select - DDR3 - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered | Product Type | Memory module | Capacity | 4 GB | Memory Type | DDR3 SDRAM - DIMM 240-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 1600 MHz (PC3-12800) | Latency Timings | CL11 (11-11-11-30) | Features | Unbuffered | Voltage | 1.5 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Capacity | 4 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR3 SDRAM |
Form Factor | DIMM 240-pin |
Voltage | 1.5 V |
Expansion / Connectivity | |
Compatible Slots | 1 x memory - DIMM 240-pin |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
