Corsair 4GB (1x4GB) DDR3 1333Mhz CL9 Value Select Desktop Memory Module
£19.59
Delivery:
Standard: 1-3 working days
  • Type: DDR3 SDRAM, DDR3
  • Capacity: 4GB, 1-4GB
  • Connection: DIMM 240-pin, DIMM
  • Speed: 1333MHz, 1066-1600Mhz
  • Data Integrity: Non-ECC
Product codes
chevron icon
chevron icon
Corsair Memory 4GB Single Module 1333MHz CL 9-9-9-24 1.5V DDR3 DIMM for Intel and AMD platform system builds and upgrades. Corsair built its reputation on performance memory that shines in the most demanding computing situations: extreme gaming and high-transaction processing environments. But not all computers are put to such extreme usage. So we brought the same reliability, testing and Corsair quality to a line of memory designed to support standard computing situations such as popular office applications. Now it's one of our most popular memory lines. Backed with a lifetime warranty, it is memory you can rely on
  • Density: 4GB
  • Speed: 1333MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5
  • Single 4GB Module
  • DDR3
  • 1333MHz performance Latency of 9-9-9-24 to maximize system performance
  • 100% Guaranteed compatibility with all Intel and AMD DDR3 platforms
  • Limited Lifetime Warranty
chevron icon
Product Description CORSAIR Value Select - DDR3 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Product Type Memory kit
Capacity 4 GB: 2 x 2 GB
Memory Type DDR3 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1333 MHz (PC3-10600)
Latency Timings CL9 (9-9-9-24)
Features Unbuffered
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£19.59
