CX Series™ Modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, and easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes the CX Series Modular quieter at idle, and reduces noise even when you’re pushing your system hard. The matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look.
Product Description | CORSAIR CX-M Series CX550M - 2015 Edition - power supply - 550 Watt | Device Type | Power supply - internal | Specification Compliance | ATX12V 2.4/ EPS12V 2.92 | 80 PLUS Certification | 80 PLUS Bronze | Weight | 3.27 kg | Localisation | United Kingdom | Input Voltage | AC 100-240 V | Output Voltage | +3.3, +5, ±12 V | Power Capacity | 550 Watt | Output Current | +3.3V - 20 A , +5V - 20 A , +12V - 45.8 A , -12V - 0.8 A , +5VSB - 3 A | Output connectors | 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector | Modular Cable Management | Yes | Cooling System | 120 mm fan | Colour | Matte black | Dimensions (WxDxH) | 15 cm x 14 cm x 8.6 cm | Manufacturer Warranty | 5-year warranty |
General | |
PSU Form Factor | ATX |
Power Device | |
Frequency Required | 47 - 63 Hz |
Power Output Connectors Details | 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector |
Miscellaneous | |
Features | Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, semi-modular |
Compliant Standards | TUV, BSMI, CB, CCC, FCC, RoHS, WEEE, ICES, cTUVus, KC, China RoHS, RCM, CU-TR |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 15 cm |
Depth | 14 cm |
Height | 8.6 cm |
Weight | 3.27 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 21.6 cm |
Shipping Depth | 29 cm |
Shipping Height | 13 cm |
Shipping Weight | 3.53 kg |
