The cloth surface of the MM200 delivers excellent glide characteristics that allow you to execute fast swipes and pull off high-precision shots with confidence and consistency. It's optimized for gaming sensors, with a carefully-screened surface material that delivers excellent tracking.
You can't afford to have your mouse surface move in the middle of a firefight, so Corsair added a non-slip base that provides cushion with just the right amount of give. And it's made of natural rubber, so it doesn't have a harsh chemical odor.
Product Description | CORSAIR Gaming MM200 Compact Edition - mouse pad | Product Type | Mouse pad | Product Material | Rubber, cloth | Dimensions (WxDxH) | 26.5 cm x 21 cm | Manufacturer Warranty | 1-year warranty |
General | |
Width | 26.5 cm |
Depth | 21 cm |
Thickness | 0.2 cm |
Miscellaneous | |
Features | Non-slip |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
