Corsair Gaming Strafe MX Silent Mechanical Keyboard in Red LED
Product Description | CORSAIR Gaming STRAFE Mechanical - keyboard - UK | Device Type | Keyboard | Backlit | Red | Interface | USB | Connectivity Technology | Wired | Localization and Layout | UK | Keys Qty | 105 | Hot Keys Function | Multimedia, Windows key lock | Numeric Keypad | Yes | Features | USB hub | Gaming | Yes | Key Switch Type | CHERRY MX Silent | Dimensions (WxDxH) | 44.8 cm x 21.9 cm x 4.8 cm | Weight | 1.37 kg | Manufacturer Warranty | 2-year warranty |
General | |
Backlit | Red |
Interface | USB |
Input Device | |
Keys Qty | 105 |
Keyboard Technology | Mechanical |
Gaming | Yes |
Adjustable Height | Yes |
Features | USB hub, numeric keypad |
Width | 44.8 cm |
Depth | 21.9 cm |
Height | 4.8 cm |
Weight | 1.37 kg |
Expansion / Connectivity | |
Interfaces | USB pass-through |
Miscellaneous | |
Included Accessories | Keycap puller, FPS & MOBA keycap sets |
Software & System Requirements | |
OS Required | Microsoft Windows 7 / 8 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
