Crucial DDR4 4 GB SO-DIMM 260-pin 2666 MHz PC4-21300 - CL19
£14.42
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • DIMM type is unbuffered
  • Makes everything on your laptop faster
  • Easy to install
  • Type: DDR4 SDRAM, DDR4
  • Capacity: 4GB, 1-4GB
  • Connection: SO-DIMM 260-pin, SO DIMM
  • Speed: 2666MHz, 2000-2999Mhz
  • Data Integrity: Non-ECC
Product codes
chevron icon
chevron icon
The Crucial 260-pin are used in 4GB DDR4 memory for laptop which has reliable performance and high-quality memory module that have been specifically designed and developed for industrial / embedded computers, automation and system builds where product quality is key for long term deployment.
chevron icon
Product Description Crucial - DDR4 - module - 4 GB - SO-DIMM 260-pin - 2666 MHz / PC4-21300 - unbuffered
Product Type Memory module
Capacity 4 GB
Memory Type DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 2666 MHz (PC4-21300)
Latency Timings CL19 (19-19-19)
Features Single rank, unbuffered
Voltage 1.2 V
Manufacturer Warranty Limited lifetime warranty (Germany - 10 years)
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£14.42
