Enjoy home security in high definition. Crisp HD video gives you a clear view of what's going on at home. See more of your favorite faces and places - it's home security with an eye for detail.
Product Description | D-Link DCS 936L HD Wi-Fi Camera - network surveillance camera | Device Type | Network surveillance camera - fixed | Audio | Yes: built-in microphone | Dimensions (WxDxH) | 6.5 cm x 4.8 cm x 8.05 cm | Weight | 141 g | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Max Resolution | 1280 x 720 | Frame Rate (max) | 30 frames per second | Optical Sensor Type | CMOS - 1/4" - 1 MP | Minimum Illumination | 0 lux - IR | Focal Length | 2.45 mm | Lens Iris | F/2.4 | Voltage | DC 5 V | Features | Motion sensor, sharpness control, saturation control, brightness control, contrast control, infrared cut filter, hue control, Wi-Fi Protected Setup (WPS), text stamp, password protection, sound sensor | Environmental Parameters (operating) | 0 °C - 40 °C; 20 - 85% (non-condensing) relative humidity |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in microphone |
Width | 6.5 cm |
Depth | 4.8 cm |
Height | 8.05 cm |
Weight | 141 g |
Camera | |
Type | Colour - Day&Night - fixed |
Digital Video Format | MJPEG, H.264 |
Max Digital Video Resolution | 1280 x 720 |
Digital Zoom | 4 |
Infrared LEDs | Yes |
Infrared Distance | 4.88 m |
Video Capture | 1280 x 720 @ 30 fps , 640 x 352 @ 30 fps , 320 x 176 @ 30 fps |
Supported Image Formats | JPEG |
Image Sensor | |
Type | 1 MP CMOS 1/4" |
Lens Construction | |
Lens Iris | F/2.4 |
Horizontal Field of View (degree) | 100 |
Vertical Field of View (degree) | 54 |
Interfaces | |
Network Protocols | DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, RTCP, PPPoE |
Expansion / Connectivity | |
Supported Memory Cards | microSD Card, microSDXC Card |
Miscellaneous | |
Compliant Standards | FCC Class B certified, C-Tick, ICES, LVD |
Power | |
Power Requirements | DC 5 V - 1.2 A |
Power Device | Power adapter - external (50/60 Hz) |
Software / System Requirements | |
Software Included | Drivers & Utilities, mydlink Lite |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Relative Humidity (operating) | 20 - 85% (non-condensing) |
