The DGS-3630 Series Layer 3 Stackable Managed Switch is designed for Small Medium Businesses (SMBs), Small Medium Enterprises (SMEs), enterprises, and ISPs. It delivers high-performance, flexibility, fault tolerance, and advanced software features for maximum return on investment. With Gigabit Ethernet SFP, 10 GbE SFP+, security features, and advanced Quality of Service (QoS), the DGS-3630 Series can act as core, distribution or access layer switches. High port densities, switch stacking, and easy management make the DGS-3630 Series suitable for a variety of applications.
Product Description | D-Link DGS 3630-52TC - switch - 52 ports - Managed - rack-mountable | Device Type | Switch - 52 ports - L3 - Managed - stackable | Enclosure Type | Rack-mountable | Ports | 44 x 10/100/1000 + 4 x combo Gigabit SFP + 4 x 10 Gigabit SFP+ | Performance | Switching capacity: 176 Gbps , Forwarding performance: 130.95 Mpps , Stacking bandwidth: 80 Gbps | Capacity | IPv4 routing table entries: 16000 , IPv6 routing table entries: 7000 , IPv4 forwarding table entries: 32000 , IPv6 forwarding table entries: 16000 , VLAN groups: 4000 , Dynamic VLAN entries: 4000 , Static ARP entries: 512 , IPv4 routes (static): 512 , IPv6 routes (static): 256 , QoS hardware queues per port: 8 , ACL entries (egress): 4000 , ACL entries (ingress): 1000 | MAC Address Table Size | 68K entries | Jumbo Frame Support | 12KB | Routing Protocol | BGP-4, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, PIM-SSM, MSDP, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), DVMRPv3, RIPng, MLDv2, MLD, BGP-4+, VRRPv2, Bidirectional Forwarding Detection (BFD), VRRPv3, URPF | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, TFTP, CLI | Features | ARP support, IGMP snooping, DoS attack prevention, packet filtering, port mirroring, WRR queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Dying Gasp support, sFlow, PIM snooping, tunnelling, DHCP snooping, ACL support, QoS, IP Precedence, DHCP server, VRF-Lite, MLD snooping, DAI, Safeguard Engine, Cable Diagnostics Function, bandwidth control, LLDP support, Port Security, RSPAN, SNMP trap, DHCP client, Energy Efficient Ethernet, GVRP, SP, Loopback, TFTP client, 4MB packet buffer, 802.1x authentication, Duplicated Address Detection, TRTCM, ToS, PTP, DSCP support, 2 fans, IGMP filtering, SRTCM, IP source guard, Head of Line Blocking Prevention, host based access control, PFC, VTP, BPDU, Link Aggregation, MIB II, SSM, DDM, NTP, AAA, VLAN Double Tagging (Q-in-Q), Loop Guard, ERPS v2, VLAN mirroring, MLD filtering, WAC, SRM | Compliant Standards | IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.1AX, IEEE 802.1Qbb | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44.1 cm x 26 cm x 4.4 cm | Weight | 4.04 kg | Manufacturer Warranty | Limited lifetime warranty |
General | |
Max Units In A Stack | 9 |
Encryption Algorithm | MD5, SSL, TLS 1.0, TLS 1.1 |
Authentication Method | RADIUS, TACACS+, Secure Shell v.2 (SSH2) |
Status Indicators | Status |
Expansion / Connectivity | |
Interfaces | 48 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP , 4 x 10GBase-X SFP+ , 1 x console RJ-45 management , 1 x management (Gigabit LAN) RJ-45 , 1 x USB 2.0 Type A , 1 x alarm RJ-45 , 1 x console (mini-USB) |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 62 Watt |
Miscellaneous | |
MTBF | 263,936 hours |
Compliant Standards | FCC Class A certified, VCCI, C-Tick, BSMI, cUL, CB, CCC, ITU Y.1731 |
Software / System Requirements | |
Software Included | Standard Image (SI) Software |
Dimensions & Weight | |
Width | 44.1 cm |
Depth | 26 cm |
Height | 4.4 cm |
Weight | 4.04 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | -5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 95% |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 95% |
