D-Link DUB-E100 - network adapter - USB 2.0 - 10/100 Ethernet
£26.49
Delivery:
Notify me
Key features
  • Can be used right away without requiring any configuration
  • Create a fast, reliable wired connection to your network by simply plugging it into your PC
  • Reduces power usage during light traffic or when Ethernet cable is unplugged
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Wired Ethernet
  • Form Factor: External
  • Compatibility: PC, Mac
  • Type: Network adapter, Adapters
Product codes
chevron icon
The DUB-E100 is a high-speed USB 2.0 10/100Mbps Fast Ethernet adapter for Windows-based desktop and notebook PCs. This adapter is designed to simply plug into any available Universal Serial Bus (USB) port on your computer to connect you to a Fast Ethernet network. Based on USB 2.0, the adapter extends the transfer speed of earlier USB Fast Ethernet adapters to true 10/100Mbps connectivity.
The USB port of the adapter gives you throughput of up to 480Mbps to your computer. That's about 40 times faster than USB 1.1, the earlier USB specification. Now you can take full advantage of your Fast Ethernet network speed to transfer files, send e-mail and upload/download images.
As a USB device, this adapter eliminates the need to open your computer's cover to plug a network card into an expansion slot. It also saves your notebook's PC Card slot for other use. Installation and use are further simplified by living up to USB's out-of-the-box installation approach to connecting computer peripherals. You will not have to set IRQ's and other settings for your network connection. configuration is automatic at computer power up, and the adapter is hot pluggable. The DUB-E100 is equipped with an attached USB 2.0 cable that directly connects to any USB port on your computer. It is backward compatible with USB 1.1, so you can use the adapter with USB 1.1 ports as well (in case no USB 2.0 port is available). The DUB-E100 represents the simplest way to connect your computer to an Ethernet-based network.
The DUB-E100 supports USB's energy saving suspend and resume function to minimize power consumption, which is especially useful for laptop/notebook users. Power is provided directly by the USB bus, eliminating the need for an external AC power adapter.
chevron icon
Product Description D-Link DUB-E100 - network adapter - USB 2.0 - 10/100 Ethernet
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports 10/100 Ethernet
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX
Data Link Protocol 10Mb LAN, 100Mb LAN
Data Transfer Rate 100 Mbps
Compliant Standards IEEE 802.3, IEEE 802.3u
System Requirements Linux, Apple MacOS X 10.4 - 10.7, Microsoft Windows Vista / XP / 7 / 8
Microsoft Certification Works with Windows Vista
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£26.49
Notify me
