Protect your home and loved ones with the mydlink Home Smoke Detector. A built-in audio alarm alerts you whenever smoke is detected and sends a push notification to your smartphone or tablet when you're away from home. It's easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub. It works with other mydlink Home devices, such as the Smart Plug which can turn on a light when smoke is detected at night, or Siren to give you a loud audio warning either in a different part of your home or even at a location away from your home. mydlink Home enables you to create a smart home without complicated set up, installation costs or monthly subscription charges.
Product Description | mydlink Home Smoke Detector - smoke sensor - Z-Wave | Product Type | Smoke sensor | Functions | Siren | Integrated Components | Alarm | Connectivity | Wireless - Z-Wave | Supported Host Device OS | iOS, Android | Dimensions (WxDxH) | 12 cm x 5.3 cm x 12 cm |
General | |
Functions | Siren |
Connectivity Technology | Wireless - Z-Wave |
Features | Push notification |
Miscellaneous | |
Included Accessories | CR123A lithium battery |
Encryption Algorithm | 128-bit AES |
Compliant Standards | FCC |
Dimensions & Weight | |
Width | 12 cm |
Depth | 5.3 cm |
Height | 12 cm |
Weight | 130 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 49 °C |
Humidity Range Operating | 10 - 85% (non-condensing) |
