An 11.6-inch laptop that provides a cost-effective learning solution built with best-in-class durability to withstand every school day.
Good past the last bell: With at least 10 hours of battery life, this trusty PC gets kids through even the longest school days.
Designed to be kid-proof: The Chromebook 3180 Education laptop comes with a sealed, spill-resistant keyboard, rubberized edges and Drop Protection, so it can withstand lockers, lunchrooms, backpacks and buses.
Collaborative construction: A 180-degree hinge allows the system to lay flat, making it easier to share content on the Corning Gorilla Glass screen with up to 10x higher scratch resistance.
Product Description | Dell Chromebook 11 3180 - 11.6" - Intel Celeron - N3060 - 4 GB RAM - 16 GB eMMC | Product Type | Chromebook - 180-degree hinge design | Operating System | Chrome OS | Processor | Intel Celeron N3060 / 1.6 GHz, up to 2.48 GHz / 2 MB Cache | Memory | 4 GB LPDDR3 (provided memory is soldered) | Storage | 16 GB eMMC | Display | 11.6" 1366 x 768 / HD | Graphics | Intel HD Graphics 400 | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac | Battery | 3-cell | Security | Trusted Platform Module (TPM 1.2) Security Chip | Colour | Black | Dimensions (WxDxH) | 30.33 cm x 20.6 cm x 2.075 cm | Weight | 1.2652 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return | Bundled Services | 1 Year Dell Collect and Return Service |
General | |
Operating System | Google Chrome OS |
Processor / Chipset | |
CPU | Intel Celeron N3060 / 1.6 GHz |
Max Turbo Speed | 2.48 GHz |
Number of Cores | Dual-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Features | Intel Burst Technology |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1600 MHz |
Storage | |
Main Storage | 16 GB eMMC |
Display | |
Type | 11.6" |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Brightness | 200 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 400 |
Camera | Yes - 720p |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC5650 |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 7265 |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 42 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 (BC1.2 charging) , HDMI |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Black |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
