Activate Windows Hello via an infrared camera to facilitate facial recognition for easy and secure access. The Latitude 5490 offers multiple security options to meet your diverse security needs. Features include essential multi-factor authentication hardware such as touch fingerprint reader, contacted FIPS 201 Smart Card Reader, and Contactless Smart Card Reader NFC to prevent unauthorized access.
Product Description | Dell Latitude 5490 - 14" - Intel Core i5 - 8250U - 4 GB RAM - 500 GB HDD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 500 GB HDD / 7200 rpm | Display | 14" WLED 1366 x 768 / HD | Graphics | Intel UHD Graphics 620 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Black | Dimensions (WxDxH) | 33.34 cm x 22.89 cm x 2.05 cm | Weight | 1.6 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 1 year - response time: next business day |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8250U / 1.6 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2400 MHz |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA / 7200 rpm |
Display | |
Type | 14" |
LCD Backlight Technology | WLED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare, Wide Viewing Angle |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1280 x 720 |
Resolution | 1 Megapixel |
Image Sensor Type | CMOS |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | Fixed focus |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3246 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19.5 V, 3.34 A |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , HDMI , VGA , USB-C (supports DisplayPort Alt Mode) , LAN |
Memory Card Reader | Yes (SD Card) |
Software | |
Software Included | Microsoft Office (Trial), McAfee (30 days trial) |
Miscellaneous | |
Colour | Black |
Features | Free Fall Sensor, MIL-STD-810G tested, HDD isolation |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Compliant Standards | FIPS 140-2, TCG Certified |
Dimensions & Weight | |
Weight | 1.6 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
