A 15.6" laptop built for ultimate productivity and performance. It features excellent security features.
Product Description | Dell Latitude 5580 - 15.6" - Intel Core i5 - 7300U - vPro - 8 GB RAM - 500 GB HDD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Platform Technology | Intel vPro Platform | Processor | Intel Core i5 (7th Gen) - 7300U / 2.6 GHz, up to 3.5 GHz / 3 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 500 GB HDD / 7200 rpm | Display | 15.6" 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Input Device | Pointing stick | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM) Security Chip, smart card reader | Colour | Black | Dimensions (WxDxH) | 37.6 cm x 25.07 cm x 2.325 cm | Weight | 1.9 kg | Pricing Type | Build To Stock (BTS) | Environmental Standards | - EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - response time: next business day |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7300U / 2.6 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA / 7200 rpm |
Display | |
Type | 15.6" |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 300 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 1280 x 720 |
Resolution | 0.92 Megapixel |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC3246 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad, pointing stick |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19.5 V, 3.34 A |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , 2 x USB 3.0 , USB 3.0 (PowerShare) , USB-C (supports DisplayPort Alt Mode) , LAN , HDMI , VGA |
Memory Card Reader | Yes (SD Card) |
Software | |
Software Included | Microsoft Office (Trial) |
Miscellaneous | |
Colour | Black |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 1.9 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
