UK/BTS/Lati 7310/Core i5-10310U/16GB/256GB SSD/13.3" FHD CF/Intel UHD/ThBlt & FgrPr & SmtCd/Cam & Mic/WLAN + BT/Backlit Kb/4 Cell/W10Pro/vPro/3Y Basic Onsite.
Product Description | Dell Latitude 7310 - 13.3" - Core i5 10310U - vPro - 16 GB RAM - 256 GB SSD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - Multilingual User Interface (MUI) | Platform Technology | Intel vPro Platform | Processor | Intel Core i5 (10th Gen) 10310U / 1.7 GHz (4.4 GHz) / 6 MB Cache | Memory | 16 GB DDR4 (1 x 16 GB) | Storage | 256 GB SSD - NVMe, Class 35 | Display | 13.3" LED backlight 1920 x 1080 / Full HD @ 60 Hz - 166 ppi | Graphics | Intel UHD Graphics | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac/ax, Bluetooth 5.1 | Battery | 4-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 30.65 cm x 20.319 cm x 1.827 cm | Weight | 1.22 kg | Pricing Type | Build To Stock (BTS) | Environmental Standards | ENERGY STAR Qualified EPEAT Gold | Bundled Services | 3 Years Basic Onsite |
General | |
Operating System | Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI) |
Processor / Chipset | |
CPU | Intel Core i5 (10th Gen) 10310U / 1.7 GHz |
Max Turbo Speed | 4.4 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 16 GB (1 x 16 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - NVM Express (NVMe), Class 35 |
Display | |
Type | 13.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
V-Sync Rate at Max Res. | 60 Hz |
Widescreen | Yes |
Pixel Density (ppi) | 166 |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Corning Gorilla glass, anti-glare, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate |
Audio & Video | |
Graphics Processor | Intel UHD Graphics |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes |
Video Resolutions | 1080p |
Frame Rate | 30 frames per second |
Camera Features | 78.6 degrees, RGB camera |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3254 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac/ax, Bluetooth 5.1 |
Wireless Controller | Intel Wi-Fi 6 AX 201 |
Battery | |
Technology | 4-cell |
Capacity | 52 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19.5 V, 3.25 A |
Connections & Expansion | |
Interfaces | USB 3.2 Gen 1 (PowerShare) , USB-C 3.2 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , USB-C 3.2 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , Headphone/microphone combo jack , HDMI |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Software | |
Software Included | Microsoft Office (30 days trial) |
Miscellaneous | |
Colour | Black |
Case Material | Carbon fibre |
Features | ExpressCharge |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | USB-C power adapter |
Dimensions & Weight | |
Weight | 1.22 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 95% (non-condensing) |
Shock Tolerance (operating) | 140 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 160 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.66 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.3 g @ RMS (random) |
