This 14" business-class laptop is incredibly mobile without compromise. Featuring great security, manageability and reliability.
Product Description | Dell Latitude 7480 - 14" - Intel Core i7 - 7600U - vPro - 8 GB RAM - 256 GB SSD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (7th Gen) - 7600U / 2.8 GHz, up to 3.9 GHz / 4 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD | Display | 14" 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM) Security Chip, smart card reader | Colour | Black | Dimensions (WxDxH) | 33.1 cm x 22.09 cm x 1.841 cm | Weight | 1.36 kg | Pricing Type | Build To Stock (BTS) | Environmental Standards | - EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 3 years - response time: next business day |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7600U / 2.8 GHz |
Max Turbo Speed | 3.9 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 14" |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - HD |
Image Sensor Type | CMOS |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | Fixed focus |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC3246 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad |
Features | Multi-gesture touch pad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19.5 V, 3.34 A |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , 2 x USB 3.0 , USB 3.0 (PowerShare) , USB-C (supports DisplayPort Alt Mode) , LAN , HDMI |
Memory Card Reader | Yes (SD Card) |
Software | |
Software Included | Microsoft Office (Trial) |
Miscellaneous | |
Colour | Black |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 1.36 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
