Versatile design. Exceptional experience. The Latitude 7490 is a business-class laptop built with premium materials.
Product Description | Dell Latitude 7490 - 14" - Intel Core i7 - 8650U - vPro - 16 GB RAM - 512 GB SSD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (8th Gen) - 8650U / 1.9 GHz, up to 4.2 GHz / 8 MB Cache | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 512 GB SSD | Display | 14" 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 620 | Input Device | Pointing stick | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 33.1 cm x 22.09 cm x 1.79 cm | Weight | 1.4 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 3 years - response time: next business day |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8650U / 1.9 GHz |
Max Turbo Speed | 4.2 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2400 MHz |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 512 GB SSD M.2 2280 SATA |
Display | |
Type | 14" - IPS |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 300 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Camera | Yes - HD |
Resolution | 0.92 Megapixel |
Image Sensor Type | CMOS |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | Fixed focus |
Sound | Stereo speakers, array microphone |
Codec | Realtek ALC3246 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad, pointing stick |
Features | Multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell |
Capacity | 60 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 90 Watt |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , USB-C (supports Thunderbolt 3, DisplayPort Alt Mode) , LAN , HDMI , USB-C 3.1 Gen 1 (PowerShare) |
Memory Card Reader | Yes (SD Card) |
Software | |
Software Included | Microsoft Office (Trial), McAfee (30 days trial) |
Miscellaneous | |
Colour | Black |
Case Material | Magnesium alloy |
Features | Noise reduction |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 1.4 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - response time: next business day |
