The N1100 switch series offers a power-efficient Gigabit Ethernet (GbE) network-access switching solution with integrated 1GbE and 10GbE uplinks. With high-performance capabilities and wire-speed performance, utilizing a non-blocking architecture to easily handle unexpected traffic loads, the switches offer simple management and scalability via a 1Gbps (full-duplex) high availability stacking architecture that allows management of up to four switches from a single IP address.
Product Description | Dell Networking N1108T-ON - switch - 8 ports - Managed - rack-mountable | Device Type | Switch - 8 ports - Managed - stackable | Enclosure Type | Front to back airflow rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 + 2 x Gigabit SFP | Performance | Switching fabric bandwidth: 24 Gbps , Forwarding performance: 18 Mpps | Capacity | MAC addresses: 16000 , Aggregated links (dynamic): 144 , LAG groups: 64 , Queues per port: 8 , VLANs supported: 512 , ARP entries: 2048 , NDP entries: 400 , Max ACL rules system-wide: 4000 , ACL: 100 , Maximum ACL rules per interface (IPv4) ingress rules: 1023 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv6) ingress rules: 1021 , Maximum ACL rules per interface (IPv6) egress rules: 253 | MAC Address Table Size | 16000 entries | Routing Protocol | IGMPv2, IGMP, IGMPv3 | Remote Management Protocol | SNMP 2, SNMP, RMON, Telnet, HTTP, TFTP, SSH-2 | Features | Layer 2 switching, MDI/MDI-X switch, auto-negotiation, port mirroring, IP address filtering, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, Remote Switch Port Analyzer (RSPAN), Management Information Base (MIB), dual firmware images, redundant fans, MAC and IP-based ACLs support, Time-controlled ACLs support | Compliant Standards | IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.3ax | Dimensions (WxDxH) | 21.6 cm x 25.4 cm x 4.45 cm | Weight | 1.6 kg | Manufacturer Warranty | Limited lifetime warranty |
General | |
Encryption Algorithm | AES, SSL, TLS 1.0 |
Authentication Method | RADIUS, TACACS+, LDAP |
RAM | 1 GB |
Flash Memory | 1 GB |
Expansion / Connectivity | |
Interfaces | 8 x Gigabit LAN RJ-45 , 2 x Gigabit LAN SFP , 2 x Gigabit LAN RJ-45 management , 1 x USB Type A , 1 x |
Power | |
Power Device | Internal power supply |
Installed Qty | 1 |
Power Provided | 24 Watt |
Miscellaneous | |
Compliant Standards | FCC Class A certified, UL, cUL, GS, RoHS, WEEE, REACH, ICES Class A, NRTL, VCCI Class A, EAC, CCC Class A, FDA 21CFR1040.10, ACMA, FDA 21CFR1040.11, RCM Class A |
Dimensions & Weight | |
Width | 21.6 cm |
Depth | 25.4 cm |
Height | 4.45 cm |
Weight | 1.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 95% |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 65 °C |
Humidity Range Storage | 85% |
