Essential 19.5" All-in-One desktop with business-class performance and a sleek space-saving design.
Brilliant at every angle: Picture every detail in stunning clarity with a 19.5" Wide Viewing Angle WLED display with HD+ (1600x900) resolution.
Feel the difference: The optional ten point multi-point touch screen allows you to interact with your tasks, as well as clients through customer facing touch applications.
Created for collaboration: Integrated speakers, a dual array microphone, and an HD web camera, along with Microsoft Skype for Business certification, deliver collaboration and communication capabilities for both video and telephone conferencing.
Power your success: Equipped with up to 7th and 6th Gen Intel processors for comprehensive Operating System support.
Upgraded everywhere: The 3050 AIO delivers a smoother and more efficient work experience with up to 16GB of DDR4 memory and a variety of storage solutions, including high performance solid state drives.
Work with confidence: With optional WLAN cards, the sleek and VESA capable 3050 AiO can be set up anywhere there's WiFi and a power outlet.
Less clutter, more versatility: This flexible AIO offers multiple wireless options, while streamlining all connections to one single plug for a cleaner and more functional workspace.
Design your workspace: An Articulating Easel and Height Adjustable stand options allow you work the way that works best for you.
Stay connected with ease: Multiple port options improve the way you work by creating an easy and centralized way to connect and share from your devices.
Product Description | Dell OptiPlex 3050 All In One - all-in-one - Core i5 7500T 2.7 GHz - 4 GB - HDD 500 GB - LED 19.5" | Type | Personal computer - all-in-one | Processor | Intel Core i5 (7th Gen) 7500T / 2.7 GHz (, up to 3.3 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | HDD 500 GB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD | Monitor | 19.5" - LED - 1600 x 900 (HD+) - 16:9 | Graphics Controller | Intel HD Graphics 630 | Camera | Yes | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2 | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Microsoft Office (Trial) | Colour | Black | Dimensions (WxDxH) | 48.26 cm x 5.89 cm x 32.87 cm | Weight | 3.6 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 1 year - response time: next business day |
General | |
Type | Personal computer |
Product Form Factor | All-in-one - with Easel Stand |
Built-in Devices | Stereo speakers |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7500T |
Clock Speed | 2.7 GHz |
Max Turbo Speed | 3.3 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel B250 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD-ROM DVD - SATA |
Monitor | |
Monitor Type | LED |
Diagonal Size | 19.5" |
Native Resolution | 1600 x 900 (HD+) |
Widescreen Display | Yes |
Image Aspect Ratio | 16:9 |
Monitor Features | Anti-glare |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | DisplayPort |
Camera | |
Camera | Yes |
Resolution | HD |
Input Device | |
Type | Mouse (on selected markets only), keyboard (on selected markets only) |
Mouse | |
Technology | Optical |
Interface | USB |
Audio Input | |
Type | Two microphones |
Networking | |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 3165 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x internal 2.5" x 1/8H |
Interfaces | 3 x USB 3.0 , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x headphones/microphone , 1 x USB 3.0 (PowerShare) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Device Type | Power supply |
Power Provided | 130 Watt |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI) |
Software | Microsoft Office (Trial) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - response time: next business day |
Dimensions & Weight | |
Width | 48.26 cm |
Depth | 5.89 cm |
Height | 32.87 cm |
Weight | 3.6 kg |
