The Dell OptiPlex Micro Vertical Stand is Designed for those with limited desk space, the Micro Vertical Stand instantly creates more room by dramatically reducing the OptiPlex footprint. This clean, simple stand is an easy way to safely configure an OptiPlex Micro systems in an upright position. It helps in minimize desktop clutter and aids in organization. Also provides easy access to all ports on your OptiPlex Micro system. With access clear to both the front and rear panels, the Micro Vertical Stand makes it easy to run appropriate cabling and connect peripherals. The vertical mounting option also provides a stylish look for workspaces requiring a specific aesthetic. Moreover, this compact and convenient solution seamlessly upgrades your OptiPlex experience.
Product Description | Dell OptiPlex Micro Vertical Stand - system desk stand | Product Type | System desk stand | Designed For | OptiPlex 3000 Thin Client, 3020 (micro), 3040 (micro), 3046 (micro), 3050 (micro), 3070 (micro), 3090 (micro), 5050 (micro), 5070 (micro), 5080 (micro), 7040 (micro), 7050 (micro), 7080 XE Micro Form Factor, 9020 (micro) |
General | |
Compatibility Information | |
Designed For | Dell OptiPlex 3000 Thin Client, 3020 (micro), 3040 (micro), 3046 (micro), 3050 (micro), 3070 (micro), 3090 (micro), 5050 (micro), 5070 (micro), 5080 (micro), 7040 (micro), 7050 (micro), 7080 XE Micro Form Factor, 9020 (micro) |
