Samsung TV Promotion: Save up to £250 across the range.
Dell P2422HE 23.8" 1920x1080 8ms HDMI DisplayPort USB-C LED Monitor
£188.84
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Stay productive, no matter where you work. Reduce harmful blue light with this sleek 23.8-inch FHD hub monitor with ComfortView Plus.
  • Diagonal Size: 24in, 23-25 inches
  • Max Resolution: 1920 x 1080, Widescreen
  • Response Time: 5ms, 4-8ms
  • Speakers: None, No Speakers
  • Interfaces: DisplayPort, USB-C, HDMI
Product codes
chevron icon
chevron icon
chevron icon
Product Description Dell P2422HE - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class D
Power Consumption (On mode) 14.5 W
Features USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support 16.7 million colours
Colour Gamut 99% sRGB
Input Connectors HDMI, DisplayPort, USB-C
Built-in Ethernet Yes
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Voltage AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand 53.78 cm x 17.95 cm x 49.61 cm
Weight 6 kg
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services 3-Years Advanced Exchange Service and Premium Panel Guarantee
Designed For Latitude 5320, 5520; Precision 7560; Vostro 14 5410, 15 5510
chevron icon
Accessories
Accessories
Other bundles
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£188.84
