Experience unrestrained innovation with the thinner and lighter, premium-built Precision mobile workstations. Built with Intel 6-core processors, blazing-fast memory and professional graphics, the Precision mobile family is engineered with power that rivals your own ingenuity.
Product Description | Dell Precision 3530 - 15.6" - Core i7 8850H - vPro - 16 GB RAM - 256 GB SSD | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - Multilingual User Interface (MUI) | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (8th Gen) 8850H / 2.6 GHz (4.3 GHz) / 9 MB Cache | Memory | 16 GB DDR4 (1 x 16 GB) | Storage | 256 GB SSD - NVMe | Display | 15.6" WLED 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro P600 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, smart card reader | Colour | Black | Dimensions (WxDxH) | 37.6 cm x 25.07 cm x 2.43 cm | Weight | 2.03 kg | Pricing Type | Build To Plan (BTP) | Manufacturer Warranty | Limited warranty - 3 years - response time: next business day |
General | |
Operating System | Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI) |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8850H / 2.6 GHz |
Max Turbo Speed | 4.3 GHz |
Number of Cores | 6-core |
Cache | 9 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM246 |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 16 GB (1 x 16 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe) |
Display | |
Type | 15.6" |
LCD Backlight Technology | WLED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Colour Gamut | 72% |
Features | Anti-glare, PremierColor technology, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle |
Audio & Video | |
Graphics Processor | NVIDIA Quadro P600 |
Camera | Yes |
Resolution | 0.92 Megapixel |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | 74 degrees |
Sound | Stereo speakers, array microphone |
Codec | Realtek ALC3246-CG |
Compliant Standards | High Definition Audio, Wave MAXXAudio Pro |
Input | |
Type | Keyboard, touchpad |
Features | Precision touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0 |
Wireless Controller | Intel Wireless-AC 9560 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Features | Wake-on-LAN (WOL) |
Battery | |
Technology | 4-cell |
Capacity | 68 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 130 Watt, 19.5 V, 6.67 A |
Connections & Expansion | |
Interfaces | USB-C (supports Thunderbolt 3, DisplayPort Alt Mode) , LAN , 2 x USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , VGA , HDMI , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card, Memory Stick, MultiMediaCard, Memory Stick PRO-HG Duo, SDHC Card, SDXC Card, Memory Stick XC, SDXC UHS-II Card, SDXC UHS Card, Memory Stick PRO-HG) |
Miscellaneous | |
Colour | Black |
Features | Microphone with noise-cancellation |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 2.03 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - response time: next business day |
