Experience unrestrained innovation with the thinner and lighter, premium-built Precision mobile workstations. Built with Intel 6-core processors, blazing-fast memory and professional graphics, the Precision mobile family is engineered with power that rivals your own ingenuity.
Product Description | Dell Precision 5530 - 15.6" - Core i7 8850H - vPro - 16 GB RAM - 256 GB SSD | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - Multilingual User Interface (MUI) | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (8th Gen) 8850H / 2.6 GHz (4.3 GHz) / 9 MB Cache | Memory | 16 GB DDR4 (1 x 16 GB) | Storage | 256 GB SSD | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro P1000 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Ethernet | Battery | 3-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Silver | Dimensions (WxDxH) | 35.7 cm x 23.5 cm x 1.7 cm | Weight | 1.78 kg | Pricing Type | Build To Plan (BTP) | Manufacturer Warranty | Limited warranty - 3 years - response time: next business day |
General | |
Operating System | Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI) |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8850H / 2.6 GHz |
Max Turbo Speed | 4.3 GHz |
Number of Cores | 6-core |
Cache | 9 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM246 |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 16 GB (1 x 16 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 400 cd/m² |
Colour Gamut | 72% |
Features | UltraSharp, Premium Panel Guarantee, Wide Viewing Angle |
Audio & Video | |
Graphics Processor | NVIDIA Quadro P1000 |
Camera | Yes |
Resolution | 0.92 Megapixel |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | 66 degrees |
Sound | Stereo speakers, dual array microphone |
Compliant Standards | High Definition Audio, Wave MAXXAudio Pro |
Input | |
Type | Keyboard, touchpad |
Features | Multi-finger touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0 |
Wireless Controller | Intel Dual Band Wireless-AC 9260 |
Network Interface | Ethernet |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 56 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 130 Watt, 19.5 V, 6.67 A |
Connections & Expansion | |
Interfaces | USB-C 3.1 Gen 2 (supports Thunderbolt 3) (Power Delivery) , LAN (on supplied cable) , 2 x USB 3.1 Gen 1 (PowerShare) , Headphone/microphone combo jack , HDMI |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Silver |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter, USB-C to Ethernet adapter |
Dimensions & Weight | |
Weight | 1.78 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
Shock Tolerance (operating) | 140 g @ 2 ms |
Shock Tolerance (non-operating) | 160 g @ 2 ms |
Vibration Tolerance (operating) | 0.66 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.3 g @ RMS (random) |
