ITEM | QTY | PRICE |
Epson T9451 XL Size - Black Original...
4 | £281.76 |
Experience unrestrained innovation with the thinner and lighter, premium-built Precision mobile workstations. Built with Intel 6-core processors, blazing-fast memory and professional graphics, the Precision mobile family is engineered with power that rivals your own ingenuity.
Product Description | Dell Precision 7530 - 15.6" - Intel Core i7 - 8750H - 16 GB RAM - 256 GB SSD - with 3-year ProSupport | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - Multilingual User Interface (MUI) | Processor | Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 256 GB SSD | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro P1000 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad, pointing stick | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, smart card reader | Colour | Black | Dimensions (WxDxH) | 37.76 cm x 25.13 cm x 2.995 cm | Weight | 2.52 kg | Pricing Type | Build To Plan (BTP) | Manufacturer Warranty | Limited warranty - 3 years - response time: next business day | Bundled Services | 3 Years ProSupport |
General | |
Operating System | Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI) |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8750H / 2.2 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
Cache | 9 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM246 |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 128 GB |
Technology | DDR4 SDRAM |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Features | UltraSharp, anti-glare, Wide Viewing Angle |
Audio & Video | |
Graphics Processor | NVIDIA Quadro P1000 |
Camera | Yes - 1280 x 720 |
Resolution | 0.92 Megapixel |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3281 |
Compliant Standards | High Definition Audio |
Audio Features | Output: noise-cancellation technology |
Input | |
Type | Keyboard, touchpad, pointing stick |
Features | Multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0 |
Wireless Controller | Intel Dual Band Wireless-AC 9260 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Features | Wake-on-LAN (WOL) |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 64 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 180 Watt, 19.5 V, 9.23 A |
Connections & Expansion | |
Interfaces Details | Mini DisplayPort , LAN , HDMI , 2 x USB-C (supports Thunderbolt 3) , 2 x USB 3.1 Gen 1 , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous | |
Colour | Black |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 2.52 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - response time: next business day |
