Dell U2718Q UltraSharp 27" 3840x2160 8ms HDMI LED LCD Monitor
Key features
  • See the whole picture
  • A captivating view
  • Color consistency comes standard
  • Uncompromised images
  • Get it all done
Product codes
chevron icon
chevron icon
With your UltraSharp monitor you get more than a pretty picture - it's a gorgeous screen made for multitasking. Featuring a striking color depth of 1.07 billion colors, your work is presented in outstanding detail, even in dark or brightly lit areas.
Dell HDR combines greater depth of colors, remarkable clarity and a high contrast range of shades to create strikingly realistic images.
Your UltraSharp monitor is factory calibrated at 99.9% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Each monitor features a factory calibration report that guarantees color correctness, so you can trust your projects reflect true color intensity.
chevron icon
Product Description Dell UltraSharp U2718Q - LED monitor - 4K - 27" - HDR
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 44 kWh
Power Consumption (On mode) 30 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Pixel Pitch 0.1554 mm
Brightness 350 cd/m²
Contrast Ratio 1300:1
Response Time 5 ms (fast), 8 ms (normal)
Colour Support 1.07 billion colours
Colour Gamut 80.7% DCI-P3, 99.9% sRGB, 99.98% Rec 709
Input Connectors HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 61.13 cm x 20.03 cm x 41.02 cm
Weight 6.23 kg
Compliant Standards Plug and Play, DDC/CI, RoHS, NFPA 99, halogen-free, EDID compatible, BFR-free, HDCP 2.2
Designed For Latitude 7400 2-in-1; XPS 13 9380, 15 9570, 15 9575 2-in-1
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
