Laptop with security and connectivity small business demands. Featuring fast processors, PC/smartphone integration and a numeric keypad.
Product Description | Dell Vostro 3581 - 15.6" - Core i3 7020U - 4 GB RAM - 1 TB HDD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i3 (7th Gen) 7020U / 2.3 GHz / 3 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 1 TB HDD / 5400 rpm | Optical Drive | DVD-Writer | Display | 15.6" 1366 x 768 / HD @ 60 Hz | Graphics | Intel HD Graphics 620 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Ethernet | Battery | 3-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Black | Dimensions (WxDxH) | 38 cm x 25.8 cm x 2.27 cm | Weight | 2 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 1 year | Bundled Services | 1 Year Dell Collect and Return Service |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i3 (7th Gen) 7020U / 2.3 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 1 TB HDD SATA / 5400 rpm |
Display | |
Type | 15.6" - TN |
Resolution | 1366 x 768 (HD) |
V-Sync Rate at Max Res. | 60 Hz |
Widescreen | Yes |
Features | Ultra Slim Design, anti-glare, ±40° horizontal viewing angle |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - HD |
Resolution | 0.92 Megapixel |
Image Sensor Type | CMOS |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | 720p HD movie recording, fixed focus, 78.6 degrees |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC3246 |
Compliant Standards | High Definition Audio |
Audio Features | Output: MaxxAudio Pro |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Dell Wireless 1810 |
Network Interface | Ethernet |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 42 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V, 2.31 A |
Connections & Expansion | |
Interfaces | HDMI , Headphone/microphone combo jack , USB 2.0 , 2 x USB 3.1 Gen 1 , LAN , VGA |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Software | |
Software Included | Microsoft Office (Trial), McAfee (30 days trial) |
Miscellaneous | |
Colour | Black |
Features | Noise reducing microphone |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 140 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 160 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.66 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.3 g @ RMS (random) |
