ITEM | QTY | PRICE |
Fairphone 5 TPU Case Sky Blue
3 | £89.94 |
A small, light 14" laptop that combines seamless connectivity and security options for a professional task master you can count on.
Product Description | Dell Vostro 5481 - 14" - Core i5 8265U - 8 GB RAM - 256 GB SSD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - Multilingual User Interface (MUI) | Processor | Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD | Display | 14" LED backlight 1920 x 1080 / Full HD - 157 ppi | Graphics | Intel UHD Graphics 620 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 3-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Colour | Silver | Dimensions (WxDxH) | 32.49 cm x 23.2 cm x 1.82 cm | Weight | 1.55 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return | Bundled Services | 1 Year Dell Collect and Return Service |
General | |
Operating System | Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI) |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8265U / 1.6 GHz |
Max Turbo Speed | 3.9 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2400 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Pixel Density (ppi) | 157 |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare, ±80° horizontal viewing angle, ±80° vertical viewing angle |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1280 x 720 |
Image Sensor Type | CMOS |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | 720p HD movie recording |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3204 |
Compliant Standards | High Definition Audio |
Audio Features | Output: MaxxAudio Pro |
Input | |
Type | Keyboard, touchpad |
Features | Multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 3165 |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Realtek RTL8111 |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 42 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V, 2.31 A |
Connections & Expansion | |
Interfaces | 2 x USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card) |
Software | |
Software Included | Microsoft Office (Trial), McAfee (30 days trial) |
Miscellaneous | |
Colour | Silver |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 1.55 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Shock Tolerance (operating) | 105 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.26 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.37 g @ RMS (random) |
