The XPS 13 Ultrabook is slim and features a 13.3" display cleverly fit into a footprint that's similar to an 11" laptop. XPS 13 Ultrabook feels as good as it looks, thanks to a comfort-designed keyboard and a sleek, gesture-enabled glass touch pad.
The XPS 13 Ultrabook boots from cold in as little as 12 seconds. Whatever state your laptop is in, it comes back in a snap, less than 3 seconds when it's in sleep mode and less than 5 seconds from deep sleep.
Product Description | Dell XPS 13 9365 2-in-1 - 13.3" - Core i5 8200Y - 8 GB RAM - 256 GB SSD - with 1-year ProSupport | Product Type | Notebook - flip design | Operating System | Win 10 Pro 64-bit - Multilingual User Interface (MUI) | Processor | Intel Core i5 (8th Gen) 8200Y / 1.3 GHz (3.9 GHz) / 4 MB Cache | Memory | 8 GB LPDDR3 | Storage | 256 GB SSD | Display | 13.3" touchscreen 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 615 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | 4-cell | Security | Fingerprint reader | Colour | Silver | Dimensions (WxDxH) | 30.42 cm x 19.85 cm x 1.37 cm | Weight | 1.24 kg | Pricing Type | Build To Stock (BTS) | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year | Bundled Services | 1 Year Dell ProSupport |
General | |
Operating System | Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI) |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8200Y / 1.3 GHz |
Max Turbo Speed | 3.9 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Rated Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe |
Display | |
Type | 13.3" |
Touchscreen | Yes |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Features | Infinity Edge display |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 615 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes |
Resolution | 0.92 Megapixel |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | 74.6 degrees |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3271 |
Audio Features | Output: MaxxAudio Pro |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 46 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 30 Watt |
Connections & Expansion | |
Interfaces | USB-C 3.1 (supports DisplayPort Alt Mode) (PowerShare) , Thunderbolt 3 (PowerShare) , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC UHS) |
Software | |
Software Included | Microsoft Office (Trial), McAfee (30 days trial) |
Miscellaneous | |
Colour | Silver |
Features | Battery life Indicator |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | USB-C power adapter |
Dimensions & Weight | |
Weight | 1.24 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 140 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 160 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.66 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.3 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
