The small 13-inch laptop with captivating Dell Cinema and next-gen InfinityEdge. Featuring an 8th Gen Intel Quad Core processor in a stunning look.
Product Description | Dell XPS 13 9370 - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD - with 1-year ProSupport | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - Multilingual User Interface (MUI) | Processor | Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD - NVMe | Display | 13.3" touchscreen 3840 x 2160 / Ultra HD 4K | Graphics | Intel UHD Graphics 620 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 4-cell - up to 19 hours | Security | Fingerprint reader | Colour | Silver | Dimensions (WxDxH) | 30.176 cm x 19.924 cm x 1.16 cm | Weight | 1.27 kg | Pricing Type | Build To Stock (BTS) | Manufacturer Warranty | Limited warranty - 1 year | Bundled Services | 1 Year Dell ProSupport |
General | |
Operating System | Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI) |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8250U / 1.6 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Rated Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe) |
Display | |
Type | 13.3" |
Touchscreen | Yes |
Resolution | 3840 x 2160 (Ultra HD 4K) |
Widescreen | Yes |
Features | Corning Gorilla glass 4, Infinity Edge display |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - HD |
Resolution | 0.92 Megapixel |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | Windows Hello, infrared emitter |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3271-CG |
Audio Features | Output: MaxxAudio Pro |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Killer Wireless-AC 1435 |
Features | Miracast |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 52 Wh |
Run Time | Up to 19 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, DC 5 / 9 / 15 / 20 V |
Connections & Expansion | |
Interfaces | USB-C (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB-C (supports Thunderbolt 3) (Power Delivery) , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Software | |
Software Included | Microsoft Office (Trial), McAfee (30 days trial) |
Miscellaneous | |
Colour | Silver |
Case Material | Aluminum |
Features | Battery life Indicator |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Noble Wedge security slot |
Included Accessories | USB-C power adapter |
Dimensions & Weight | |
Weight | 1.27 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 110 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 160 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.66 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.3 g @ RMS (random) |
