The DJI Goggles are comfortable goggles designed for seamless FPV flying with DJI products.They combine a pair of ultra-high quality screens, long range low lag wireless connectivity, and direct control of photo and video capture. With Intelligent Flight Modes like ActiveTrack, TapFly, Terrain Follow, Cinematic Mode and Tripod mode, a totally new flying dimension is created.
Product Description | DJI Goggles - virtual reality headset - Full HD (1080p) | Device Type | Virtual reality headset | Features | Remote control, touchpad, antenna, microSD card reader | Sensors | Accelerometer, proximity sensor, gyro sensor, head tracking sensor | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 30 Hz | Resolution per Eye | 5" - 1920 x 1080 | Field of View | 85° | Battery Run Time | Up to 6 hours | Colour | White | Dimensions (WxDxH) - body | 19.5 cm x 15.5 cm x 11 cm | Weight | 495 g | Localisation | United Kingdom | Compliant Standards | HDCP 1.2 |
General | |
Display Type | Virtual reality headset |
Built-in Devices | Antenna, microSD card reader |
Features | HDCP |
Colour | White |
Dimensions (WxDxH) | 19.5 cm x 15.5 cm x 11 cm - body |
Weight | 495 g |
VR Headset | |
Resolution per Eye | 1920 x 1080 |
Diagonal Size per Eye | 5" |
Control Type | Touchpad |
Audio | |
Type | Speakers |
Input | |
Type | Remote control, touchpad |
Connectivity | |
Interfaces | Micro-USB , HDMI , Headphones |
Miscellaneous | |
Included Accessories | Cleaning cloth, headband, wire clip |
Cables Included | 1 x micro-USB cable , 1 x HDMI cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Battery | |
Capacity | 9440 mAh |
Run Time (Up To) | 6 hours |
Dimensions & Weight | |
Dimensions & Weight Details | Headband - width: 25.5 cm - depth: 20.5 cm - height: 9.2 cm - weight: 500 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
