Osmo Mobile 3 is foldable, portable, and incredibly convenient to use everywhere you go. Its 3-axis gimbal effectively eliminates shake, delivering smooth and stable footage.
Product Description | DJI Osmo Mobile 3 motorised handheld stabiliser | Product Type | Motorised handheld stabiliser | Dimensions (WxDxH) | 13 cm x 4.6 cm x 15.7 cm | Weight | 405 g | Head Type | Gimbal | Manufacturer Warranty | 1-year warranty |
General | |
Width | 13 cm |
Depth | 4.6 cm |
Height | 15.7 cm |
Weight | 405 g |
Tripod | |
Supported Devices | Mobile phone |
Foldable | Yes |
Features | Battery operated, 3-axis stabilisation |
Head | |
Head Positioning | 3-way |
Pan (degrees) | +170.3/-162.5 |
Tilt (degrees) | +235.7/-104.5 |
Tripod Mount | 1/4" screw |
Kit Content | |
Kit Content | (1) x power cable , (1) x pouch , (1) x wrist strap , (4) x anti-skid pad |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
