An uprated camera is equipped with a 1-inch 20-megapixel sensor capable of shooting 4K/60fps video and Burst Mode stills at 14 fps. The adoption of titanium alloy and magnesium alloy construction increases the rigidity of the airframe and reduces weight, making the Phantom 4 Pro similar in weight to the Phantom 4. The FlightAutonomy system adds dual rear vision sensors and infrared sensing systems for a total of 5-direction of obstacle sensing and 4-direction of obstacle avoidance.
Product Description | DJI Phantom 4 Pro+ - quadcopter | Product Type | Quadcopter | Included Items | Micro-USB cable, battery charger, power cable, carrying case, 4 propellers, 16 GB MicroSD card, gimbal clamp, intelligent flight battery, USB OTG cable, remote controller with built-in display | Category | Vehicles - drones | Compatibility | iPhone, iPad, Android phone | Camera | Included - 20 Megapixel | Navigation | GPS/GLONASS receiver | Interface | USB, Wi-Fi | Colour | White | Weight | 1.388 kg |
General | |
Size | 350 mm |
Remote Control | Yes - 5.8 GHz - max operating distance: 7 km |
Power Source | Battery |
Supported Flash Memory Cards | microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card, microSD Class 10 up to 128 GB |
Features | Obstacle avoidance system |
RC Vehicle | |
Take-Off Weight | 1388 g |
Vertical Hovering Accuracy | +/- 0.1 metres |
Horizontal Hovering Accuracy | +/- 0.3 metres |
Max Angular Velocity | 250° per second |
Max Tilt Angle | 42° |
Max Horizontal Velocity | 20 metres per second |
Max Ascent Speed | 6 metres per second |
Max Descent Speed | 4 metres per second |
Max Wind Speed Resistance | 10 metres per second |
Wi-Fi Bands | 2.4 GHz, 5 GHz |
Gimbal | |
Control Accuracy | 0.02° |
Control Angle Range | -90 to 30° |
Max Speed | +/- 90° per second |
Digital Camera | |
Sensor Resolution | 20 Megapixel |
Image Sensor Type | CMOS |
Capture Formats | H.264, MP4, MOV, H.265 |
Video Recorder Resolutions | 1280 x 720 (720p), 1920 x 1080 (1080p), 3840 x 2160 (2160p), 4096 x 2160, 2720 x 1530 |
Frame Rate | 60 frames per second |
Still Image Formats | JPEG, RAW, DNG |
Still Image Resolutions | 5472 x 3648, 4864 x 3648, 5472 x 3078 |
Max View Angle | 84 degree(s) |
Battery | |
Supported Battery Configurations | 4S |
Technology | Lithium polymer |
Voltage | 15.2 V |
Capacity | 5870 mAh |
Run Time | Up to 30 min |
Controller Battery | 1 x 2S |
Miscellaneous | |
Colour | White |
Weight | 1.388 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
