SPARK
Seize the Moment
Meet Spark, a mini drone that features all of DJI's signature technologies, allowing you to seize the moment whenever you feel inspired. With intelligent flight control options, a mechanical gimbal, and a camera with incredible image quality, Spark empowers you to push your creative boundaries.
Quick Launch
With FaceAware, Spark lifts off from your hand by recognizing your face.1 It takes off and hovers in place within seconds of powering on.
Simple Control
Take amazing aerial photos using just hand gestures, without a remote controller or mobile device
Create with Ease
Intelligent Flight Modes and intuitive controls help you create cinematic aerial videos with just a few taps.
Edit and Share
The DJI GO 4 app features automatic editing templates and an array of filters. Quickly edit videos and share them straight to social media.
Amazing images and stabilized video
Mechanical Gimbal Stabilization - Shake-Free Shots:
Spark's 2-axis mechanical gimbal and UltraSmooth technology dramatically reduce shake and rolling shutter effect, keeping shots stable and detailed.
Powerful Lens - Capture the World:
All Spark images are consistently sharp and vivid with very little color aberration and distortion. Spark's camera has an f/2.6 wide-angle lens with a 25 mm equivalent focal length. Five elements are arranged into a single group that fit into a compressed frame.
1/2.3" Sensor - Record More Details:
Small and compact, Spark's camera features a 1/2.3 inch CMOS sensor, allowing you to shoot stabilized video at 1080p and stills at 12 MP. Larger pixels mean Spark is acutely sensitive to light and records colors precisely.
Flight Performance
Speed and Precision Control
With its aerodynamic, lightweight, and slick design, Spark soars through the air with minimal wind resistance. The gimbal and camera are flush with the aircraft, significantly increasing stability. Powerful propulsion offers steady flight in strong winds at up to 31 mph (50 kph) in Sport Mode.2 And an advanced flight control system means flying Spark is fun and intuitive.
Fly Farther, See More
Innovative HD Wi-Fi technology allows for 720p real-time video transmission from up to 1.2 mi (2 km) away.
Uncompromised Flight Time
Even with all of Spark's intelligent features, flight time isn't compromised. Fly for up to 16 minutes with a fully-charged battery, capturing more footage
Aerial Immersion
Switch to Sport Mode and unleash Spark's speed potential. Sport Mode sets the gimbal mode to FPV by default, so the camera moves with you as you fly. For an upgraded FPV experience, pick up a pair of DJI Goggles and see a different world.
In The Box
- Aircraft
- Propeller Pair
- 1 x Intelligent Flight Battery
- Charger
- Micro USB Cable
- Storage Box
Drone Code
Please take a moment to familiarise yourself with the Drone code before flying your drone. When you fly a drone in the UK it is your responsibility to be aware of the rules that are in place to keep everyone safe. Follow these simple steps to make sure you are flying safely and legally.
On 30 July the UK drone rules changed to make it against the law to fly above 400ft (120m) and to make it against the law to fly your drone within 1km of an airport or airfield boundary.
For more information visit: https://dronesafe.uk/drone-code/
Product Description | DJI Spark - Mini Drone | Product Type | Mini Drone | Included Items | Micro-USB cable, charger, storage box, intelligent flight battery | Category | Vehicles - drones | Compatibility | iPhone, iPad, Android phone | Camera | Included - 12 Megapixel | Max Speed | 50 kilometers per hour | Interface | Wi-Fi | Width | 14.3 cm | Depth | 14.3 cm | Height | 5.5 cm | Weight | 300 g |
General | |
Remote Control | Yes - 5.8 GHz - max operating distance: 2 km |
Power Source | Battery |
Supported Flash Memory Cards | microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card up to 64 GB |
RC Vehicle | |
Take-Off Weight | 300 g |
Vertical Hovering Accuracy | +/- 0.1 metres |
Horizontal Hovering Accuracy | +/- 0.3 metres |
Max Vertical Velocity | 3 metres per second |
Max Horizontal Velocity | 13.9 metres per second |
Interface | Wi-Fi |
Gimbal | |
Control Angle Range | -85 to 0° |
Digital Camera | |
Sensor Resolution | 12 Megapixel |
Image Sensor Type | CMOS |
Capture Formats | MP4 (MPEG-4 AVC/H.264) |
Video Recorder Resolutions | 1920 x 1080 (1080p) |
Frame Rate | 30 frames per second |
Still Image Formats | JPEG |
Still Image Resolutions | 3968 x 2976 |
Max View Angle | 81.9 degree(s) |
Battery | |
Rechargeable Battery | Rechargeable |
Supported Battery Configurations | 3S |
Technology | Lithium polymer |
Voltage | 11.4 V |
Capacity | 1480 mAh |
Run Time | Up to 16 min |
Recharge Time | 52 min |
Miscellaneous | |
Available in | Alpine white, sky blue, meadow green, lava red, sunrise yellow |
Dimensions | 14.3 cm x 14.3 cm x 5.5 cm |
Weight | 300 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
