We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Epson-compatible scanners can be shared across departments and workgroups, thanks to the Epson Network Interface Panel with Push Scan features.
Product Description | Epson Network Scan Module - scanner server - 10/100 Ethernet | Device Type | Scanner server | Form Factor | External | Ports | 10/100 Ethernet | Dimensions (WxDxH) | 15.9 cm x 8.3 cm x 7 cm | Weight | 318 g | Cabling Type | Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T | Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE | Data Transfer Rate | 1000 Mbps | System Requirements | Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x | Manufacturer Warranty | 1-year warranty | Designed For | Epson DS-6500, DS-7500; WorkForce DS-50000, DS-50000N, DS-5500, DS-5500N, DS-60000, DS-60000N, DS-6500, DS-6500N, DS-70000, DS-70000N, DS-7500, DS-7500N |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Miscellaneous | |
Mounting Kit | Included |
Software / System Requirements | |
OS Required | Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x |
Dimensions & Weight | |
Width | 15.9 cm |
Depth | 8.3 cm |
Height | 7 cm |
Weight | 318 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Compatibility Information | |
Designed For | Epson DS-6500, DS-7500 , Epson WorkForce DS-50000, DS-50000N, DS-5500, DS-5500N, DS-60000, DS-60000N, DS-6500, DS-6500N, DS-70000, DS-70000N, DS-7500, DS-7500N |
