1ST IMPACT PACKAGED PRINTER * PS, NES; Serial;Epson Cool White (ECW); Power Supply.
Product Description | Epson TM U220A - receipt printer - colour - dot-matrix | Printer Type | Receipt printer - dot-matrix - 9 pin - colour | Weight | 2.7 kg | Localisation | France | Max Media Size | Roll (7.6cm) | Max Media Size (Custom) | 76 mm | Print Speed | Up to 6 lines/sec | Max Resolution (B&W) | 16 cpi | Max Resolution (Colour) | 16 cpi | Interface | Serial | Language Simulation | EPSON ESC/POS | Total Media Capacity | 1 roll | Enclosure Colour | Cool white | Dimensions (WxDxH) | 16 cm x 28.6 cm x 15.8 cm |
General | |
Printer | |
Connectivity Technology | Wired |
Media Handling | |
Media Sizes | Roll (7 cm), Roll (7.6cm), Roll (5.8 cm) |
Media Feeders | 1 x manual - 1 roll - Roll (7.6cm) |
Expansion / Connectivity | |
Connections | 1 x RS-232 - 9 pin D-Sub (DB-9) |
Miscellaneous | |
Included Accessories | Cutter, take-up reel |
MTBF | 180,000 hour(s) |
Compliant Standards | FCC Class A certified, CSA, UL, TUV, EN 60950, EN55022, VCCI Class A ITE, EN55024 |
Power | |
Power Device | Power adapter - external |
Power Consumption Operational | 31 Watt |
Power Consumption Stand by / Sleep | 2.2 Watt |
Software / System Requirements | |
Software Included | Driver |
Dimensions & Weight | |
Width | 16 cm |
Depth | 28.6 cm |
Height | 15.8 cm |
Weight | 2.7 kg |
