Epson WorkForce DS-410 Document scanner Duplex A4 600 dpi 26ppm
£260.73
Delivery:
Notify me
Key features
  • Great productivity features at a competitive price
  • Protect originals and ensure every page is scanned
  • Insert pages and the scanner will start automatically
  • Make it easy to scan multiple pages
  • Allows ad-hoc scanning of larger-format originals
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: A4 (210 x 297 mm), A4
  • Interface: USB 2.0, USB
  • Compatibility: Mac, PC
Product codes
chevron icon
The DS-410 provides a range of invaluable productivity features including double feed detection and paper protection technology to make sure originals are protected and every page is scanned. A set of advanced LED sensors detects when two pieces of paper have been picked at once, instantly stopping the machine and alerting the user. Meanwhile paper protection helps prevent misfeeds and damage by stopping automatically when the device detects stapled or skewed documents.
It has automatic feed mode for fast and simple scanning - just insert sheets and the scanner will begin, while a 50-sheet automatic document feeder makes it easy to scan large piles of documents.
The DS-410 has a robust build to handle everything office life can throw at it, and a very compact body to take up minimal desk space, so it's easy to fit into even the smallest of offices. It can scan at speeds of up to 26ppm/52ipm, and handle paper weights from 50g/m to 209g/m . Also, manual A3 mode allows ad-hoc scanning of larger-format originals.
The scanner is bundled with Epson's new Document Capture Pro 2.0 software, which offers a simple but powerful software solution for scanning, separating and routing documents throughout a business.
chevron icon
Product Description Epson WorkForce DS-410 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scanning Sensor Type Contact Image Sensor (CIS)
Light Source LED
Max Supported Document Size A4 (210 x 297 mm)
Input Type Colour
Optical Resolution 600 dpi x 600 dpi
Interpolated Resolution 1200 dpi x 1200 dpi
Max Document Scan Speed 26 ppm (mono) / 26 ppm (colour)
Max Document Size 216 mm x 3048 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 3000 scans per day
Power AC 120/230 V (50 - 60 Hz)
System Requirements Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Apple MacOS X 10.7.x, Windows 8, Microsoft Windows Server 2003 R2 x64 Edition, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Apple MacOS X 10.11.x, Apple MacOS X 10.11, Apple macOS 10.12
Dimensions (WxDxH) 29.7 cm x 15.2 cm x 15.4 cm
Weight 2.5 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£260.73
Notify me
