Low TCO printing
Take advantage of a low Total Cost of Ownership (TCO), and print up to 7,000 colour and 10,000 mono pages using easy-to-change, high-capacity DURABrite Pro ink cartridges.
Ecological
Uses up to 80% less power than competitive colour lasers thanks to the no heat technology. No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the workplace. And there are fewer parts to replace than a laser.
Enhance productivity
Print at up to 34 pages per minute (ppm) in both colour and mono, with ISO print speeds of 24 ppm for both . The WF-8590DWF delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results, and features one-pass duplex scanning and a 50-sheet Automatic Document Feeder. Scalable optional paper trays take its maximum capacity to 1,831 sheets.
Built for business
Epson's PrecisionCore technology powers the output quality and reliability at the speeds required for both office and industrial printing. A smartphone-like 12.7cm colour touchscreen is easy to use, while scan-to functions, including Microsoft SharePoint4, and LDAP address book compatibility make it ideal to share documents. Also securely print using a PIN code to release confidential documents, or use Email Print for Enterprise5 to securely send documents directly to the multifunction printer.
Product Description | Epson WorkForce Pro WF-8590DWF - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Super G3 - plain paper | Printing Technology | Ink-jet (colour) | Inkjet Technology | Epson PrecisionCore - 4-ink | Monthly Duty Cycle (max) | 65000 pages | Max Copying Speed | Up to 22 ppm (mono) / up to 21 ppm (colour) | Max Copying Resolution | Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour) | Max Printing Speed | Up to 24 ppm (mono) / up to 24 ppm (colour) | Max Printing Resolution | Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Scanning | 1200 x 2400 dpi | Original Size | A3 (297 x 420 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 50 sheets | Media Size | A3 Plus (329 x 483 mm) (max) | Media Type | Envelopes, plain paper, photo paper | Standard Media Capacity | 330 sheets | Max Media Capacity | 1831 sheets | Bypass Feeder Capacity | 80 sheets | Output Trays Capacity | 250 sheets | Automatic Duplexing | Yes (copying) Yes (printing) Yes (scanning) | Connection Availability | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, save to USB flash drive, scan to Cloud | Power | AC 230 V | Dimensions (WxDxH) | 59 cm x 57 cm x 46.4 cm | Weight | 34.3 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Fax Type | Plain paper |
Printing Technology | Ink-jet - colour |
Display Features | Touch screen |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Automatic Duplexing | Yes |
Printing | |
Inkjet Technology | Epson PrecisionCore |
Nozzle Configuration | 400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Minimum Ink Droplet Size | 3.7 pl |
Ink Type | Epson DURABrite Pro inks |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 2400 dpi |
Fax Machine | |
Compatibility | Super G3 |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 550 pages |
PC Faxing | Yes |
Fax Machine Features | |
Error Correction Mode (ECM) | Yes |
Speed Dialing | 200 station(s) |
Features | Automatic redialing, colour faxing, Duplex Fax |
Document & Media Handling | |
Max Original Size | A3 (297 x 420 mm) |
Max Media Size | A3 |
Min Media Weight | 64 g/m² |
Max Media Weight | 256 g/m² |
Supported Media Type | Envelopes, plain paper, photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, A3 Plus (329 x 483 mm) |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm) |
Document & Media Handling Details | Input tray - 250 sheets , ADF - 50 sheets , Input tray - 80 sheets , Output tray - 250 sheets |
Speed Details | Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 21 ipm - colour (ISO/IEC 24735) , Scanning: up to 23 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour , Scanning: 5 sec (A4) - B/W , Scanning: 7 sec (A4) - colour |
Connections | |
Interfaces | 1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 |
Security Protocols & Features | LDAP, SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x |
Operating System Support | MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later |
Software Included | Epson Connect |
Power | |
Voltage Required | AC 230 V |
Power Consumption Operational | 39 Watt |
Power Consumption Standby | 17 Watt |
Power Consumption Sleep | 2.4 Watt |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 59 cm |
Depth | 57 cm |
Height | 46.4 cm |
Weight | 34.3 kg |
Environmental Parameters | |
Sound Emission | 52 dBA (operating) |
