ITEM | QTY | PRICE |
StarTech.com 4 Port PCI SuperSpeed US...
5 | £347.55 |
Cut your environmental impact and business printing costs, all while increasing productivity with less intervention and enhanced security.
Product Description | Epson WorkForce Pro WF-C5710DWF - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Super G3 - plain paper | Printing Technology | Ink-jet (colour) | Inkjet Technology | Epson PrecisionCore - 4-ink | Monthly Duty Cycle (max) | 45000 pages | Recommended Monthly Volume | 250 - 2500 pages | Max Copying Speed | Up to 22 ppm (mono) / up to 22 ppm (colour) | Max Copying Resolution | Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour) | Max Copying Resolution Class | Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour) | Max Printing Speed | Up to 24 ppm (mono) / up to 24 ppm (colour) | Max Printing Resolution | Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Printing Resolution Class | Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Scanning | 1200 x 2400 dpi | Original Size | A4 (210 x 297 mm), Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 50 sheets | Media Size | 64 x 127 mm (min) - 216 x 60000 mm (max) | Media Type | Envelopes, plain paper, recycled paper, glossy photo paper | Standard Media Capacity | 330 sheets | Max Media Capacity | 830 sheets | Bypass Feeder Capacity | 80 sheets | Output Trays Capacity | 150 sheets | Automatic Duplexing | Yes (copying) Yes (printing) Yes (scanning) | Connection Availability | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 42.5 cm x 53.5 cm x 35.7 cm | Weight | 18.4 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Fax Type | Plain paper |
Printing Technology | Ink-jet - colour |
Display Colour Support | Colour |
Display Features | Touch screen |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 999 |
Automatic Duplexing | Yes |
Printing | |
Inkjet Technology | Epson PrecisionCore |
Nozzle Configuration | 800 nozzles (black), 3 x 800 nozzles (cyan, magenta, yellow) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Minimum Ink Droplet Size | 3.8 pl |
Printer Drivers / Emulations | EPSON ESC/P-R |
Ink Type | Epson DURABrite Ultra inks |
First Print Out Time B/W | 5 sec |
First Print Out Time Colour | 6 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 2400 dpi |
Scanning Resolution Details | 1200 x 2400 dpi - flatbed , 1200 x 1200 dpi - ADF |
Fax Machine | |
Compatibility | Super G3 |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 550 pages |
PC Faxing | Yes |
Fax Machine Features | |
Error Correction Mode (ECM) | Yes |
Speed Dialing | 200 station(s) |
Broadcast Transmission | Yes |
Delayed Transmission | Yes |
Features | E-mail function, colour faxing |
Document & Media Handling | |
Max Original Size | A4 (210 x 297 mm), Legal (216 x 356 mm) |
Min Media Size | 64 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 64 g/m² |
Max Media Weight | 256 g/m² |
Supported Media Type | Envelopes, plain paper, recycled paper, glossy photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, B6 (125 x 176 mm) |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm) |
Document & Media Handling Details | Input tray - 80 sheets size: 64 x 127 mm - 216 x 60000 mm weight: 64 g/m² - 256 g/m² , Input tray - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , ADF - 50 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , Output tray - 150 sheets |
Speed Details | Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 15 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 15 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 22 ipm - colour (ISO/IEC 24735) , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Scanning: up to 24 ipm (A4) - B/W , Scanning: up to 24 ipm (A4) - colour , Scanning: up to 8 ipm (A4) - B/W duplex , Scanning: up to 8 ipm (A4) - colour duplex |
Connections | |
Interfaces | 2 x USB host - 4 pin USB Type A , 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45 |
Security Protocols & Features | LDAP, SSL, Apple Bonjour, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, ARP, Wi-Fi Direct |
Operating System Support | Linux, MS Windows XP SP2 or later, MS Windows XP Professional x64 Edition, MS Windows XP SP3, MS Windows XP 64-bit Edition, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, MS Windows Server 2003 R2, MS Windows Server 2003 R2 x64 Edition, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, Windows 8.1, MS Windows Server 2012 R2, MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 10, Apple Mac OS X 10.10.x, Apple Mac OS X 10.11.x, Apple Mac OS X 10.12.x |
Software Included | Drivers & Utilities, Epson Document Capture Pro |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 23 Watt |
Power Consumption Standby | 10 Watt |
Power Consumption Sleep | 1.5 Watt |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in |
Dimensions & Weight | |
Width | 42.5 cm |
Depth | 53.5 cm |
Height | 35.7 cm |
Weight | 18.4 kg |
Environmental Parameters | |
Sound Emission | 54 dBA (operating) |
