ITEM | QTY | PRICE |
StarTech.com Dual Port PCI Express Gi...
3 | £461.94 |
The EZVIZ LB1-Color Bulbs work with Alexa and Google Assistant so you can turn your lights on and off and dim and brighten them, and even change the color temperature - all with your voice! You can also use the EZVIZ App to set schedules or remote control your home lights from anywhere.
Product Description | EZVIZ LB1 - LED light bulb - frosted finish - E27 - 8 W - 16 million colours/warm to cool white light - 2700-6500 K | Light Source Type | LED light bulb | Bulb Finish | Frosted | Socket Type | E27 | Wattage | 8 W | Energy Efficiency Class | A+ | Colour of Illumination | 16 million colours/warm to cool white light | Colour Temperature | 2700-6500 K | Luminous Power | 806 lumens | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
Light Source | |
Socket Type | E27 |
Wattage | 8 W |
Dimmable | Yes |
Lifetime | 15000 hours |
Features | Adjustable colour intensity, remote controlled, power on/off timer, Wi-Fi (2.4 GHz) controlled |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Compliant Standards | CB, RoHS, WEEE, REACH |
Dimensions & Weight | |
Height | 109 mm |
Diameter | 60 mm |
Weight | 54.8 g |
Environmental Parameters | |
Min Operating Temperature | -15 °C |
Max Operating Temperature | 45 °C |
