Protective Case
Because accidents happen. Because it’s better to be safe than sorry. Because it looks really good too!
RECYCLED MATERIALS
It’s made from non-toxic 100% post-consumer recycled TPU (thermoplastic polyurethane).
SHOCK ABSORPTION
It fits perfectly to your phone, absorbing shocks for maximum protection.
PHONE COMPATIBILITY
Made for the Fairphone 5 only.
WHAT IS IN THE BOX
Only the Fairphone 5 Protective Soft Case. We like to minimize waste.
Product Description | Fairphone - back cover for mobile phone | Product Type | Back cover for mobile phone | Dimensions (WxDxH) | 7.9404 cm x 1.17 cm x 16.481 cm | Weight | 30.84 g | Material | Thermoplastic polyurethane (TPU) | Colour | Sky blue | Product Recycled Content | 100 % - made of recycled thermoplastic polyurethane (TPU) | Manufacturer Warranty | 2-year warranty | Designed For | Fairphone 5 |
General | |
Width | 7.9404 cm |
Depth | 1.17 cm |
Height | 16.481 cm |
Weight | 30.84 g |
Colour | Sky blue |
Carrying Case | |
Type | Protective cover |
Recommended Use | For mobile phone |
Protection | Shock-absorbent |
Cover Type | Back cover |
Features | Soft |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
Damaged stock - Item is new but has packaging damage
Ref: HD9K 048592 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£14.94
