This lifetime-lasting, multi-purpose USB-C 3.2 cable is reinforced with braided kevlar and nylon for exceptional durability and is designed to withstand the toughest industrial-grade stress tests (You can twist it over 50.000 times and it will keep on going). The strain relief is made from bio TPU and there’s a handy velcro-organizer attached.
The cable has futureproof C-to-C connectors and comes with the flexibility of a USB-C to USB-A adapter. It gives you the latest performance of supporting 3A and transfer speeds up to 10 Gbps, for example between your laptop and a portable hard drive. Never worry about charging cables again and cut down on e-waste with the cable that’s designed for true longevity.
Charging and data cable
USB-C to USB-C
USB-C to USB-A with adapter
USB 3.2 Gen 2x1 standard
As Fairphone 3 and Fairphone 3+ charge at 5V, you cannot experience the full performance of this charging cable. Your phone will experience a maximum of 15W charging performance.
Warranty | 2 years | Colour | Braided black and yellow | lengh | 1.2m |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
