While the Fairphone 3 battery lasts a full day on average, sometimes your days call for a bit of extra power. Using the Fairphone USB Charger, your battery charges much faster than with a regular charger, so you’re ready to go in no time!
Technical specifications:
Model: DBS15QB
Qualcomm Quick Charge 3.0
Input: 100-240V~50/60Hz 0.5A
Output: 5.0V / 3.0A/9.0V / 2.0A/12.0V / 1.5A 18.0W MAX
Average active efficiency: 82.6%
Efficiency at low load (10%): 78.8%
No-load power consumption: 0.04W
Efficiency level: VI
Color: black
Please note: the USB charging cable is sold separately
Product Description | Fairphone DBS15QB power adapter - USB - 18 Watt | Product Type | Power adapter | Colour | Black | Localisation | United Kingdom | Output Connector Type | USB | Voltage Required | AC 100-240 V (50/60 Hz) | Voltage Provided | 5 / 9 / 12 V | Max Electric Current | 3 A | Fast Charge Technology | Qualcomm Quick Charge 3.0 | Power Provided | 18 Watt | Designed For | Fairphone 3, 3+ |
General | |
Designed For | Mobile phone |
Enclosure Colour | Black |
Power Device | |
Output connectors | 4 pin USB Type A |
Compatibility Information | |
