Give your routine a boost with Fitbit Charge 6, the only fitness tracker with Google built in. Charge 6 has your essentials—like YouTube Music, Google Maps and Google Wallet—plus the fitness tools you need to crush your goals. From staying motivated and tracking your daily progress to tuning in and taking care, running your day and your routine has never been easier.
40+ exercise modes
With more than 40 unique exercise modes, you can set personal goals for everything from runs, bike rides and aerobics, to HIIT, strength training and more. Stay tuned in with stats relevant to your workout of the moment, whether you’re looking to keep the pace or maintain your target heart rate zone.
24/7 heart rate
Watching your heart rate during exercise lets you know when you’re in fat burn, cardio or peak zones so you know how hard you’re working. The more you can comfortably push yourself, the more benefits you’ll see for your heart.
Active Zone Minutes
When you work out harder, you deserve more credit. Active Zone Minutes tracks the time you spend in your target heart rate zones, giving you double minutes when you’re in cardio or peak. We do the math and show you if you’re hitting the recommended 150 minutes each week.
Cardio fitness level
Get to know your VO2 max—a measurement of how well your body uses oxygen when you’re working your hardest. Keep tabs on your score to see how you improve over time. (Requires Fitbit mobile app)
Built-in GPS
See your pace and distance during outdoor workouts—no phone necessary—using built-in GPS, then see a map of your workout route in the Fitbit mobile app. If you have your compatible phone nearby, Charge 6 connects to its GPS to help extend your tracker's battery.
All-day activity tracking
Just get moving; we’ll take care of the rest. Charge 6 tracks your steps, distance, calories burned & Active Zone Minutes 24/7.
Workout intensity map
After outdoor exercise with GPS, check your workout intensity map in the Fitbit mobile app to see your pace and heart rate zones throughout your route and learn where you put in the most effort.
SmartTrack®
Forget to start tracking? Don’t sweat it. SmartTrack automatically recognizes and records workouts like elliptical, runs, swims and more.
Timer & stopwatch
Get instant access to tools that make your life easier—like a timer for interval training and a stopwatch for tracking sets at the gym.
Product Description | Fitbit Charge 6 - champagne gold aluminium - activity tracker with infinity band - coral | Product Type | Activity tracker | Tracking Data | Distance, time, calories burned, sleep activity, heart rate, steps taken, skin temperature, blood oxygen saturation, menstrual cycle, Resting Heart Rate (RHR), breathing rate, ECG | Connectivity | NFC, Bluetooth | Navigation | GPS/GLONASS/Galileo receiver | Display | AMOLED - always-on display | Case | Aluminium, glass, resin | Band | Coral - infinity band - silicone - changeable | Input | Touch screen, push button | Notifications | Calendar, SMS, incoming calls, applications, high and low heart rate, irregular rhythm, alarm, sedentary | Features | Music remote handling, find phone function, VO2 max, automatic exercise recognition, smart Wake-Up, reminder of hydration, sleep recommendations, Sleep Score, Sleep Profile, Stress Management Score, Daily Readiness Score | Supported Host Device OS | iOS, Android | Battery | Rechargeable lithium polymer | Battery Run Time | Up to 7 day(s) | Dimensions (WxDxH) | 18.6 mm x 11.7 mm x 38.7 mm | Manufacturer Warranty | 2-year warranty |
General | |
Supported Host Device OS | Android 9.0 (Pie) or later, iOS 15 or later |
Modes | Do-not-disturb mode, 40+ sports modes, sleep mode |
Wearing Style | Wrist |
Feedback Type | Vibration alert, visual interface |
Clock Display | Yes |
Set Goals | Yes |
Sensors | Ambient light sensor, SpO2 sensor, 3-axis accelerometer, optical heart sensor, multipurpose electrical sensor, temperature sensor |
Display | |
Type | AMOLED - colour |
Always On Display (AOD) | Yes |
Connectivity | |
Wireless Interface | NFC, Bluetooth 5.0 LE |
Input Device | |
Type | Touch sensitive screen, push button |
Battery | |
Technology | Lithium polymer |
Rechargeable Battery | Yes |
Run Time (Up To) | 7 day(s) |
Recharge Time | 2 hour(s) |
Smart Watch Case | |
Case Details | Champagne gold aluminium |
Band | |
Name | Infinity band |
Changeable | Yes |
Clasp Type | Loop and peg |
Material | Silicone |
Colour | Coral |
Dimensions & Weight | |
Width | 18.6 mm |
Depth | 11.7 mm |
Height | 38.7 mm |
Miscellaneous | |
Preloaded Software | Stopwatch, Google Maps, Timer, Google Wallet |
Vibrating Alert | Yes |
Body Material | Aluminium, glass, resin |
Protection | Water-resistant |
Compliant Standards | ISO 22810 |
Included Accessories | Charging cable, wristband (Large), 6-month Fitbit Premium membership |
Environmental Parameters | |
Max Depth of Water Resistance | 50 m |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 45 °C |
Max Altitude Operating | 8000 m |
