This is an ultra-compact PC with a stylish glass surface chassis design. Ideal for various computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. The BRIX sets a higher standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect solution as a high-productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
Product Description | Gigabyte BRIX s GB-BSi5H-6200 (rev. 1.0) - Ultra Compact PC Kit - Core i5 6200U 2.3 GHz - 0 GB - no HDD | Type | PC barebone - Ultra Compact PC Kit | Processor | 1 x Intel Core i5 (6th Gen) 6200U / 2.3 GHz (, up to 2.8 GHz, (Dual-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 3 MB | Cache Per Processor | 3 MB | RAM | 0 GB (installed) / 16 GB (max) - DDR3L SDRAM | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | No HDD | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 520 | Audio Output | Stereo | Networking | GigE | Power | AC 120/230 V | OS Provided | No operating system | Dimensions (WxDxH) | 11.26 cm x 11.94 cm x 4.68 cm |
General | |
Type | PC barebone |
Product Form Factor | Ultra Compact PC Kit |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U |
Clock Speed | 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | 3 MB |
RAM | |
Installed Size | 0 GB / 16 GB (max) |
Technology | DDR3L SDRAM |
Form Factor | SO-DIMM 204-pin |
Slots | 2 (Total) / 2 (empty) |
Hard Drive | |
Type | No HDD |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 1 |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 520 |
Video Interfaces | HDMI, DisplayPort |
Max Monitors Supported | 2 |
Audio Output | |
Sound Output Mode | Stereo |
Networking | |
Ethernet Controller | Intel I219-V |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 2 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 204-pin |
Interfaces | 4 x USB 3.0 (2 front, 2 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) |
Miscellaneous | |
Included Accessories | VESA wallmount adapter |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V |
Operating System / Software | |
Dimensions & Weight | |
Width | 11.26 cm |
Depth | 11.94 cm |
Height | 4.68 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
