The Google Nest Bundle including Stand & Cable
Keep your Google Nest Cam powered with the Google Nest Cam Stand Charger. The minimalist stand includes a magnetic connector and 3 m long cable - ideal for 24/7 camera recording.
Or you can simply use it to recharge your Nest Cam (battery).
Weight: 285 g (10.05 oz)
Power cable Length: 3 m (10 ft)
Product Description | Google - charging stand | Device Type | Charging stand - external | Weight | 285 g | Localisation | United Kingdom | Output connectors | 1 x magnetic | Included Accessories | AC power adaptor | Colour | Snow | Dimensions (WxDxH) | 6.6 cm x 6.6 cm x 5.7 cm | Manufacturer Warranty | 1-year warranty | Designed For | Nest Cam |
General | |
Colour | Snow |
Power Device | |
Power Output Connectors Details | 1 x magnetic |
Miscellaneous | |
Cables Included | Power cable 3 m |
Features | Indoor use, 0° to -45° adjustable angle |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 6.6 cm |
Depth | 6.6 cm |
Height | 5.7 cm |
Weight | 285 g |
Compatibility Information | |
Designed For | Google Nest Cam |
