Hive Active Plug
Turn your straighteners off and your music on from anywhere.
-Control from your smartphone, tablet or laptop.
-Sync with other Hive products using Hive Actions.
-Schedule your appliances to switch off automatically when you don't need them.
Sunset at the beach. Lights on back home.
Schedule your bedroom lamp to come on to make your place look lived in.
Your morning coffee. Ready when you are.
Switch your coffee machine on from under the covers.
Come home to hot food.
Get dinner in the slow cooker in the morning then turn it on from work. Voila.
Product Description | Hive Active Plug - smart plug | Product Type | Smart plug | Environment | Indoor | Connectivity | Wireless | Dimensions (WxDxH) | 5.31 cm x 5.82 cm x 11 cm |
General | |
Connectivity Technology | Wireless |
Features | Up to 3000 Watt |
Miscellaneous | |
Nominal Voltage | AC 207 - 253 V |
Dimensions & Weight | |
Width | 5.31 cm |
Depth | 5.82 cm |
Height | 11 cm |
Weight | 142 g |
