The sophisticated style of the HP EliteBook 1040 G3 Ultrabook complements the ultimate performance, security, and manageability features that help bring out your finest work.
Carry less, do more
Work confidently with the thin, elegant, and durable HP EliteBook 1040 with the HP Premium Keyboard, and a strong all metal diamond cut design that passed MIL-STD 810G testing.
Productive powerhouse
Power through your day with long battery life, 6th Gen Intel® Core™ processors, up to 16 GB of memory, and PCIe SSDs that yield impressive speed and performance.
Connect and collaborate in style
Collaborate with colleagues from practically anywhere with optional WWAN, a 720p webcam, HP Noise Reduction Software and Audio by Bang & Olufsen.
Security inside and out
HP helps protect you from malware and visual hacking. HP Sure Start with Dynamic Protection protects against BIOS attacks, and the optional HP Sure View integrated privacy screen shields your screen from prying eyes with the touch of a button.
Product Description | HP EliteBook 1040 G3 Notebook - 14" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 8 GB DDR4 (provided memory is soldered) | Storage | 256 GB SSD | Display | 14" WLED 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 520 | Input Device | ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, NFC, Bluetooth 4.2, Gigabit Ethernet | Battery | 6-cell - up to 9.75 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 33.7 cm x 23.45 cm x 1.58 cm | Weight | 1.43 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - parts and labour - 1 year | Bundled Services | 3 Years HP Care Pack Pick-Up and Return Service for Travellers |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 14" |
LCD Backlight Technology | WLED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Full HD standard-viewing angle (SVA) anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - 720p |
Camera Features | 720p HD movie recording |
Sound | Stereo speakers, two microphones |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Spill-resistant, glass with chemical etched surface |
Communications | |
Wireless | 802.11a/b/g/n/ac, NFC, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I218-LM |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Battery | |
Technology | 6-cell lithium polymer |
Capacity | 45.6 Wh |
Run Time | Up to 9.75 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , USB-C , Dock , HDMI , Headphone/microphone combo jack , VGA (on supplied adapter) , LAN (on supplied adapter) |
Software | |
Software Included | HP Recovery Disc Creator, Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Spare Key, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Mobile Connect Pro, HP Image Assistant (free download) |
Miscellaneous | |
Case Material | Aluminum |
Dockable | Yes |
Features | HP DuraFinish, HP DuraKeys, HP DisplaySafe, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 2 x USB 3.0 charging port, Pre-boot Authentication, HP Sure Start with Dynamic Protection |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter, HP Dock Connector to Ethernet/VGA Adapter |
Compliant Standards | ACPI, GS, RoHS, WEEE |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.43 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year |
Get more from your purchase from one of our essential accessories
