Impressive performance that fits right in. The design looks amazing. Your business performance will look even better. Trust your mission-critical projects to an all-in-one PC that's built to handle the demands of virtually any business environment. Power your workday with a secure, enterprise-class PC that's easy to manage and just as reliable as it is stylish.
Product Description | HP EliteOne 1000 G1 - all-in-one - Core i5 7500 3.4 GHz - 8 GB - SSD 256 GB - LED 27" | Type | Personal computer - all-in-one | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-19200 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe) | Optical Storage | No optical drive | Monitor | 27" - LED - 3840 x 2160 (Ultra HD 4K) - 16:9 | Graphics Controller | Intel HD Graphics 630 | Camera | Yes | Audio Output | Stereo | Networking | 1GbE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Velocity, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP BIOSphere Gen3, HP JetAdvantage, HP PhoneWise, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download) | Dimensions (WxDxH) | 61.33 cm x 19 cm x 45.73 cm | Weight | 10.2 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Type | Personal computer |
Product Form Factor | All-in-one |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7500 |
Clock Speed | 3.4 GHz |
Max Turbo Speed | 3.8 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | Intel Q270 |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Memory Specification Compliance | PC4-19200 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express |
Features | NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | LED - IPS |
Diagonal Size | 27" |
Native Resolution | 3840 x 2160 (Ultra HD 4K) |
Widescreen Display | Yes |
Image Aspect Ratio | 16:9 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Colour Gamut | 99% sRGB |
Pixel Pitch | 0.1554 mm |
Image Brightness | 350 cd/m² |
Image Contrast Ratio | 1000:1 |
Monitor Features | Tilt stand, Ultra HD 4K anti-glare, 99% sRGB colour gamut |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | HDMI, DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio |
Speakers Included | 2 x right / left channel |
Camera | |
Camera | Yes |
Resolution (MP) | 2 Megapixel (rear), 2 Megapixel (front) |
Resolution | Full HD |
Features | IR camera, Windows Hello |
Audio Input | |
Type | Dual array microphone |
Networking | |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280 |
Interfaces | 4 x USB 3.1 Gen 1 , 1 x DisplayPort input , 1 x DisplayPort output , HDMI output , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x headphones , 2 x USB-C 3.1 (one of them is fast-charging) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | Low halogen |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Efficiency | 87% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Velocity, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP BIOSphere Gen3, HP JetAdvantage, HP PhoneWise, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download) |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 61.33 cm |
Depth | 19 cm |
Height | 45.73 cm |
Weight | 10.2 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% |
