Designed to fit the modern workspace with an updated and stylish appearance, the ultra-small HP 260 Desktop Mini PC delivers a space saving design with the essential tools you need for your growing business at an affordable price.
Product Description | HP 260 G3 - mini desktop - Core i5 7200U 2.5 GHz - 4 GB - SSD 128 GB - UK | Type | Personal computer - mini desktop | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) (Dual-Core) | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 3 MB | Cache Per Processor | 3 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 128 GB - PCI Express 3.0 - M.2 2280 - NVM Express (NVMe) | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 620 | Networking | GigE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Home 64-bit Edition | Dimensions (WxDxH) | 17.7 cm x 17.5 cm x 3.42 cm | Weight | 1.25 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 1 year - on-site |
General | |
Type | Personal computer |
Product Form Factor | Mini desktop |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | 3 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 128 GB |
Interface Type | PCI Express 3.0 |
Features | NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 620 |
Video Interfaces | VGA, HDMI |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111HSH-CG |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x internal 2.5" |
Slots | 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 1 (free) x M.2 Card - 2230/2280 |
Interfaces | 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 2 x USB 2.0 , 1 x serial , 1 x headphones/microphone (1 in front) , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop |
Security Slot Type | Kensington security slot |
Compliant Standards | UL, FCC, RoHS, WEEE |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Efficiency | 89% |
Operating System / Software | |
OS Provided | Windows 10 Home 64-bit Edition English |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year - on-site |
Dimensions & Weight | |
Width | 17.7 cm |
Depth | 17.5 cm |
Height | 3.42 cm |
Weight | 1.25 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 49.7 cm |
Shipping Depth | 12.8 cm |
Shipping Height | 22.3 cm |
Shipping Weight | 3.34 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
