Take on your everyday work at an affordable price with the HP 290 MT. Get the reliable computing power you need while minimizing the total cost of ownership-now that's a smart investment.
Product Description | HP 290 G2 - micro tower - Core i5 8500 3 GHz - 8 GB - HDD 1 TB - UK | Type | Personal computer - micro tower | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (8th Gen) 8500 / 3 GHz (, up to 4.1 GHz, (6-core) | Cache Memory | 9 MB | Cache Per Processor | 9 MB | RAM | 8 GB (installed) / 16 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | HDD 1 TB - SATA - 7200 rpm | Optical Storage | DVD-Writer | Card Reader | Yes | Graphics Controller | Intel UHD Graphics 630 | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 17 cm x 33.8 cm x 27.75 cm | Weight | 5.4 kg | Manufacturer Warranty | Limited warranty - parts and labour - 1 year - on-site |
General | |
Type | Personal computer |
Product Form Factor | Micro tower |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8500 |
Clock Speed | 3 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | Intel H370 |
Cache Memory | |
Installed Size | 9 MB |
RAM | |
Installed Size | 8 GB / 16 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | DIMM 288-pin |
Slots | 2 (Total) / 1 (empty) |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Interface Type | SATA |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD-Writer |
Card Reader | |
Type | Card reader |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 630 |
Video Interfaces | VGA, HDMI |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5" / 3.5" shared |
Slots | 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe , 1 (total) / 1 (free) x M.2 Card - 2230/2280 |
Interfaces | 4 x USB 2.0 , 1 x headphones/microphone (1 in front) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , Audio line-in , 1 x VGA , 1 x HDMI , 1 x microphone |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Efficiency | 87% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year - on-site |
Dimensions & Weight | |
Width | 17 cm |
Depth | 33.8 cm |
Height | 27.75 cm |
Weight | 5.4 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 29.1 cm |
Shipping Depth | 39 cm |
Shipping Height | 49.9 cm |
Shipping Weight | 8 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% |
